Question: oil pan removal-front exhaust?
Old Feb 8, 2011 | 12:14 PM
Jen P.'s Avatar
Default Question: oil pan removal-front exhaust?
89 civic hatchback. I'm trying to remove my oil pan to clean it. The manual says the front exhaust must be removed but I can't seem to get the bolts off. I'm afraid I'm stripping and bending them. Anyone successfully get their oil pan off? Also, any advice for how to loosen bolts w/o breaking? I've tried WD40, and also heating and cooling them. I don't have a lift or compression tools.
Old Feb 8, 2011 | 02:06 PM
There's this stuff called PB Blaster. Works well on seized bolts. Comes in a spray can like WD40.
Old Feb 8, 2011 | 02:26 PM
Mecca8383's Avatar
Some Spray Lube and a breaker bar will do....Let the Lube set for a few minutes before using the breaker bar. BTW before putting those bolts back, soak them in motor oil so it'll be easier next time you deal with that area.
Old Feb 8, 2011 | 04:59 PM
funnymonkey24's Avatar
Wont the motor oil just burn off after a few minutes, when the exhaust gets hot.
I know that works on just about everything but exhaust but i don't know
Old Feb 8, 2011 | 05:44 PM
civicexracer's Avatar
Chances are they are rusted all the way through. Unfortunately you might have to break them to get them off... PB Blaster/WD40 can only work so deep.
Execut1ve
Feb 6, 2012 07:29 AM
oilltd
Jun 10, 2008 04:06 PM
Jhong12226
May 9, 2007 04:13 AM
xthe1nonlyx
Apr 19, 2006 12:26 PM
