Rotor replacement
Old Mar 30, 2010 | 08:25 AM
stephelton's Avatar
Default Rotor replacement
Some time ago, I replaced the front brake pads on my 2001 LX sedan. I did not replace or resurface thy rotors. The brakes are now very wobbly when i brake. I'm finally going to go ahead and replace the rotors. Should I also replace the brakes? The brakes are still very new, they probably don't have more than 5000 miles on them.
Old Mar 30, 2010 | 09:31 AM
Don't run used pads on a new rotor. It's going to wear unevenly. First check that the brakes aren't dragging and overheating as that will just warp your new rotors. If nothing goes wrong, you can typically go through 2 or 3 sets of pads on the same rotor.
Old Mar 30, 2010 | 09:36 AM
stephelton's Avatar
That is worth looking in to. The brakes have been bad for a while, I'm not too optimistic about the rotor. But I'll take a look. What would I look for?
Old Mar 30, 2010 | 10:19 AM
theblackpearl's Avatar
i always check to see if there's a leak at the piston rubber boot. and make sure the sliding pins glide fine
Li'l Red
Dec 29, 2009 12:48 AM
guitar4ya
Sep 30, 2008 05:53 AM
trustdestruction
Sep 26, 2008 04:36 PM
sfazngiants
13
Dec 29, 2007 05:19 PM
jason98ex
Jun 10, 2006 11:37 AM
