setting the timing 1997 civic
Old Jun 6, 2006 | 05:09 PM
frankfurter3's Avatar
Default setting the timing 1997 civic
I'm going to reset the timing on my civic. The manual says to put a paper clip or jumper into a wiring harness underneath the passenger side kickplate. I have two harnesses. One is in its own holder with two wires coming out of it and the other has multiple wires coming out of it. Which one do I jumper?
Old Jun 6, 2006 | 08:00 PM
Phil Mygroin's Avatar
Default RE: setting the timing 1997 civic
The connector you are looking for is inside the car under the passenger side dash in the right corner. It seems as though you have found it...in a green rubber holder. The connector has only two wires coming out of it, stick the paper clip in this one. I don't know if your manual has the correct specs, but base timing is 12 degrees BTDC (plus or minus 2 degrees).
91DXBN
Mar 2, 2009 09:30 AM
reconstyle
Jan 23, 2008 05:28 AM
Legend1011
Apr 22, 2006 03:09 PM
hondadelsoldrvr
Mar 1, 2006 02:38 AM
Street Sniper
Jan 31, 2006 06:28 PM
