starts but turns off, gauges go crazy!
Old May 25, 2007 | 06:58 PM
notfast@all's Avatar
Default starts but turns off, gauges go crazy!
HELP! car starts but turns back off and wont start again, speedometer goes up even though im not moving. Does someone know what this can be???????? 00 civic si
Old May 25, 2007 | 07:13 PM
Default RE: starts but turns off, gauges go crazy!
dizzy? coil? ecu? main relay?
Old May 26, 2007 | 05:34 PM
o1derful's Avatar
Try a new/different battery, or connections. I have had this happen before.
Old May 26, 2007 | 05:46 PM
battery is good, connections?
Old May 27, 2007 | 04:49 AM
stevie b's Avatar
its most likely ur alt get a volt tester and put the leadds on ur battterie and u should have 13 volts sujm thing like 12 or 13 is fine but ne thing less then 12 its ur alt
Old May 27, 2007 | 09:33 AM
But wouldnt the battery be dead if it was the alternator?
Old May 27, 2007 | 09:39 AM
do you guys think it can just be the coil and igniter? even with only 80k miles?
Old May 27, 2007 | 02:45 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
does the car idle at all or does it just start and then turn off immediatly?
Old May 28, 2007 | 08:09 AM
well if i step on the gas it will stay on for a while but not smoothly, its as if the spark or the fuel somehow skip
tylergarcia
Aug 10, 2015 09:11 AM
Mecca8383
Mar 31, 2014 05:15 AM
rafamofon
Dec 4, 2007 07:02 PM
mpilic
Jul 26, 2005 03:50 PM
csmith999
23
Jan 19, 2005 07:52 PM
