Supercharged 2000 si
Old Jun 18, 2008 | 01:22 PM
knavin's Avatar
Default Supercharged 2000 si
I have a 2000 si with a jackson racing supercharger 8lbs. I want to upgrade to 11 psi without hondata. I have a boost timing controler and a Jacking racing FMU. Why can't I just put in bigger injectors a 3 bar map sensor.
Any ideas?
Old Jun 18, 2008 | 03:13 PM
Default RE: Supercharged 2000 si
it's safer for your engine to use a chipped ECU (hondata) and get it tuned properly. You'll also squeeze the most potential out of your setup by getting it tuned properly with a chipped ECU.
On a piggyback unit like what you are using, the ECU is still always trying to change back to stock what the FMU is altering. With a chipped ECU this won't happen and you can sell the FMU for some $$$.
Old Jun 19, 2008 | 06:33 AM
knavin's Avatar
Hey
Thanks
I still don't really understand why everyone says stay away from FMUs. It it is boost activated and I put in 472cc injectors, how can it not be safe?
I must be missing something.
Old Jun 19, 2008 | 08:05 AM
Old Jun 19, 2008 | 10:01 AM
ORIGINAL: knavin
Hey
Thanks
because of what i said earlier
you tune it with the FMU, and then the stock ECU is always trying to adjust itself to cancel out what you altered with the FMU. The stock ECU is always trying to make the car run on stock settings, and as it adjusts itself, the settings that you have changed on the FMU are always becoming less and less effective as the ECU gets closer to making what settings actually come out of the ECU stock.
Think of it as the ECU and FMU each having a number (imaginary) that corresponds to the level of a certain setting. Say that the ECU's basemap value for that setting is "0". Then you change the FMU to make that setting "-2". Well then the ECU is going to try to adjust itself over time to "+2," so that the end result when you combine the two units is an actual setting of "0" again.
Old Jun 19, 2008 | 10:07 AM
and your stock map sensor will read up to ~12 psi, that's why a 3 bar map sensor won't help you
Old Jun 19, 2008 | 03:41 PM
knavin's Avatar
Thanks for all the info. The car is my daily driver so it won't see max boost very often andI am trying to keep the budget low. I live in Canada and everything is a lot more expensive up here.
Thanks for all the great info I just wish I had more options.
Old Jun 20, 2008 | 03:31 AM
Paying for stable managment and tuning is a lot cheaper than having to replace engines, just keep that in mind
knavin
Jun 25, 2008 09:22 AM
jrsi
Feb 21, 2006 08:24 PM
Pete
Aug 27, 2005 03:52 PM
amg6975
Aug 25, 2005 10:54 PM
kingfu
Oct 6, 2004 01:09 PM
