tach help
Old Apr 21, 2009 | 09:19 PM
Hatchfan17's Avatar
Default tach help
i have a 96 civic hatchback, im doing a type R swap and my car doesnt have a tach, I dont want to mount 1 on my dash, would rly like to swap out clusters, what clusters fit in 96 civics?
Old Apr 21, 2009 | 09:28 PM
SEARCH BUTTON i pretty sure i seen this same question like last week with a few answers.....
WOW i searched for it and it was on YOUR thread your worthless here is the same reply from your other thread.
96-98 LX, EX (maybe HX too, not sure if it has a tach) clusters will work. Or, if you don't mind KPH instead of MPH, a type R cluster
Old Apr 22, 2009 | 04:05 PM
Hatchfan17's Avatar
well thank you, my next question is if i go with a type R cluster that is in kph, can i switch my speedometer out with the one from my factor cluster?
Old Apr 22, 2009 | 05:16 PM
Yes you can take the clusters apart and switch the speedometer out. This will also preserve the mileage on your odometer.
Old Apr 22, 2009 | 05:57 PM
Hatchfan17's Avatar
is it hard to swap out speedometers?
Old Apr 22, 2009 | 07:58 PM
nope
real easy
remove the front clear plastic casing from the front of the cluster, and then there's some screws on the back of the cluster holding the speedometer into the cluster.
Old Apr 22, 2009 | 08:11 PM
Hatchfan17's Avatar
cool, thnx for help so far, well after taking more and more looks at it, i didnt notice offhand that my speedometer and the type R ones are different colors, kinda wanna keep it uniform. does ne1 know newhere to get a cluster that redlines at or around 8400rpm that has a speedometer in MPH?
Old Apr 22, 2009 | 08:16 PM
there isn't a 96-98 MPH cluster with a redline above whatever the EX has, which I believe is 6800RPM.
Why does it matter to you where the physical redline is as long as the tach goes high enough?
Old Apr 22, 2009 | 08:19 PM
Hatchfan17's Avatar
was just hoping there was sumthing out there ya know, didnt rly want my redline to be off the tach, so i was just searching.
seriously_furious
Aug 9, 2006 10:44 PM
93cxOwner
Jun 1, 2006 05:01 PM
93cxcivichb
Sep 13, 2005 09:48 AM
dalifts
Dec 16, 2004 10:34 PM
