Are these faults serious for a 2003 Civic?
Old Mar 15, 2009 | 10:53 AM
fantasyvn's Avatar
Default Are these faults serious for a 2003 Civic?
Hi all, I'm new here and would be grateful for your help with buying my first car.
I'm from London and considering this 2003 Civic hatchback, which is selling for £4900. However, according to its latest MOT advisory notice, there are some faults:
Advisory Notice issued
Nearside Front Direction indicator slightly discoloured (1.5.A1d)
Centre outer cover insecure Exhaust has part of the system slightly deteriorated (7.1.1a)
Offside and nearside front lower wishbones [front] bushes tearing out
I also noticed that this car has failed all of its 3 tests - although it got passed during its retests. What is your opinion?
For those who have more time, I list below the previous test results:
My sincere thanks,
First test:
Certificate issue refused (Fail)
Reason(s) for refusal to issue Certificate
Offside Rear 40kgs off drag Rear brake binding (3.7.A.5a)
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Rear Brake disc(s) excessively scored (3.5.1h)
Offside Rear Brake disc(s) excessively pitted (3.5.1h)
Offside Rear unable to check wheel bearing Rear brake binding (3.7.A.5a)
Rear brake application uneven (3.7.A.5c)
Rear brakes release unevenly (3.7.A.6)
Nearside Rear Brake disc(s) slightly scored (3.5.1h)
Nearside Rear Brake disc(s) slightly pitted (3.5.1h)
Nearside Front Macpherson strut has slight play in the sliding bush or gland (2.5.B.1b)
Offside Front Macpherson strut has slight play in the sliding bush or gland (2.5.B.1b)
Nearside Front Brake pad(s) wearing thin (3.5.1f)
Offside Front Brake pad(s) wearing thin (3.5.1f)
Handbrake has very little reserve travel left
Rear wiper blade badly torn
Second test: on the same date
Certificate issued (Pass)
Rear wiper torn
Third test (the following year)
Offside unable to check wheel bearing Rear brake binding (3.7.A.5a)
Nearside Front Lower front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3)
Rear wiper badly torn
Fourth test (the same date)
Offside rear brake has a very slight bind
abra0101
Mar 29, 2012 10:36 AM
mountain_man
Jun 30, 2009 06:43 AM
MrAnderson1211
14
Jun 29, 2009 12:30 AM
00IntegraLS
Apr 5, 2008 02:16 AM
nollaig
Mar 1, 2006 11:06 AM
