Vtec-e. big problem. please help
Old Feb 15, 2008 | 04:23 PM
usaqmuri's Avatar
Default Vtec-e. big problem. please help
i have a problem with my civic vtec -e.
expense 11 L. when engine is hot, power is very low and than i push in the pedal The car does not accelerating quick
replaced:
spark plugs
labda sensor (oxygen)
fuel filter
checked:
cylinder pressure. ok
fuel pump pressure. ok
Old Feb 15, 2008 | 05:24 PM
Default RE: Vtec-e. big problem. please help
check timing.....
Old Feb 16, 2008 | 08:01 AM
Type RB's Avatar
Also check Intake Air Temperature Sensor - if it's not working, it'll throw off the computer's inputs possibly creating poor performace.
Also check the PCV valve - mine ran like crap for a long time, until I discovered the hose to my PCV wasn't even hooked up. It was overlooked after I repaired the blown head gasket. When I had the head off again trying to track down an oil leak (turned out to be the VTEC module), I discovered the PCV hose dangling.
Also check the air filter - a clogged filter can make a huge difference. As the engine warms up, it'll demand more air to maintain the mix.
Mass Air Pressure sensor can mess things up as well.
Is the engine 'hot?' Or just 'up to operating temperature?' Because if the engine's 'hot,' you could have other bigger issues.
Old Feb 17, 2008 | 03:18 AM
usaqmuri's Avatar
The engine is on operating temperature.
Old Feb 17, 2008 | 03:21 AM
usaqmuri's Avatar
Old Feb 17, 2008 | 03:26 PM
Type RB's Avatar
Well - check those other things...
Newbie2000ex
Nov 21, 2011 02:06 PM
liquid_force3
Aug 31, 2009 08:18 PM
blackcivicsi
Sep 12, 2006 12:21 AM
fispod
Apr 18, 2006 11:16 AM
silvercivicex98
Aug 24, 2005 08:49 PM
