what to look for when buying a civic
Old Nov 24, 2008 | 06:21 AM
dejv's Avatar
Default what to look for when buying a civic
Hi, im new to this forum
im interested in buying a honda civic 94model
what do i have to look for when buying this model, where are the weak points etc...
thanks,
Old Nov 24, 2008 | 05:08 PM
roman01112's Avatar
just observe the car. engine,interior.check for rust.
also check the suspension.and see if any of its components look bent.
Old Nov 24, 2008 | 07:03 PM
Masonn's Avatar
There's not that many weak spots with hondas, other than rust and timing belts. I don't look for a particular spot, I just do an overall check of the car:
What I do when looking at a car is get in, start it up without the stereo or air on, test all the options, let it warm up a bit. When I start, let it rev up high (5K)then shift and listen to how it shifts (no grinds, other noises it shouldnt make). While on a (not busy) road, I get it up to 40km/h and drive like I'm going around pilons and listen for any clicks, squeaks, abnormal noises etc. I test braking (full out) then go on the highway (120km/h) and listen for abnormal noises, rattles, clicks, etc. manually check the tires, check sidewalls for cracking. check over the interior, check if the timing belt was done (should be done every 100000kms). And then offer him 10% less of what he's asking, and then haggle from there. Also check under the car for rust, check the rear wheel wells for rust to see how bad it is.
(optional) Put it up on ramps and check the exhaust system for rust. While you're under there, manually check the axles for anything abnormal. front and rear suspension too.
Good luck!
SMD#
Jul 2, 2007 12:32 PM
iceland_potter
Jun 21, 2007 07:19 AM
brokenarmboy19
May 11, 2007 09:01 AM
xposigroovex
May 26, 2006 10:53 PM
Dumont
Feb 27, 2006 09:49 PM
