Question about boost/MPG?
Old May 16, 2007 | 06:48 PM
SovXietday's Avatar
Default RE: Question about boost/MPG?
ORIGINAL: Kedawei
That doesn't make sense.A supercharger is directly connected to the crankshaft by a belt. That means for every revolution of the crankshaft, the supercharger will turn a fixed number of revolutions. It's just like a cam. Without that direct, constantdrive,cam timing could not be achievable, and motors wouldn't work so well. Transmissions operate on the same principle (gearing), as well as anything connected to the crankshaft.
In order to have boost you need copious amounts of air. If the throttle isn't letting enough air in you won't get boost no matter how fast the supercharger rotors are moving.
Old May 17, 2007 | 10:35 AM
red2000Si's Avatar
Well the bottom line here is that its a lot easier to stay out of boost with a turbo instead of a sc, granted you arent using a tiny little turbo that spools at 2k. You will probably see a slight increase in fuel economy on the highway and a slight decrease inthe city so depending on where your drivingyour probably going to break even or maybe lose a2-3mpg tops.Also, a big variable on your fuel economy will be the quality of your tune .
Old May 17, 2007 | 11:49 AM
Kedawei's Avatar
ORIGINAL: SovXietday
ORIGINAL: Kedawei
Now that makes sense.
Old May 17, 2007 | 02:41 PM
johnny's Avatar
Sov knows too much. Ban him.[8D]
Big red
Sep 14, 2007 07:00 PM
kawana
May 14, 2007 03:24 PM
hansba
Jul 5, 2006 08:11 PM
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
