heavy wheels
Old Dec 23, 2007 | 09:14 AM
speedyturtle's Avatar
Default heavy wheels
alright, im getting enkie rz-5's 16's or 17's and they weigh around 22 lbs. i was wundering what kind of difference tis would make, i won't be racing or anything. will they hurt the car or gas mileage in any way.
Old Dec 23, 2007 | 05:15 PM
civicexracer's Avatar
Default RE: heavy wheels
maybe slightly lower gas mileage. takes a little more use of the power to get the wheels turning with more weight.
Old Dec 23, 2007 | 05:39 PM
Fiirkan's Avatar
And more braking power to slow them down, so you may go through brakes faster and it would increase your stopping distance. i would try and get something lighter, or look into upgrading your brakes maybe as well
Old Dec 23, 2007 | 06:16 PM
conceptualpolymer's Avatar
Check around - I bought Black Racing Pro N1s, each weighing in at 16.25 lbs. I compared the total weight of the OEM tires/wheels to that of aftermarket combinations and found that the largest set I could buy without exceeding the OEM weight was 16-inchers. BUT, pick your wheels carefully and ALWAYS check the weight.
Ride, accelerationand braking will suffer with heavier-than-stock combos. Here's my wheel/tire weight findings:
https://www.hondacivicforum.com/m_468512/tm.htm
Old Dec 23, 2007 | 07:28 PM
ic892003's Avatar
i was always a fan of those wheels, bu they are heavy , go with the 16s and you should be fine.. friend of mine has the same wheels on his ek and he brakes fine
rags2richs
Apr 7, 2008 05:10 PM
zhmendak
May 30, 2007 05:53 AM
phishy
Dec 16, 2006 03:29 PM
roudan
Jun 16, 2006 10:57 PM
ajker
Sep 12, 2005 10:06 AM
