I need some rotors
Old Sep 23, 2008 | 06:38 PM
civicexracer's Avatar
if ur brake pads still have enough friction surface left, just keep them. they'll be fine to use on the new rotors. the noise could be from the pads, but not because their low. theres metal shims on the caliper bracket the hold the brake pads in place. these shims need to be greased to prevent squealing noise. when u replace the rotors, remove the brake pads, clean up the shims with degreaser and a wire brush and put new high-temp grease on them.
Old Sep 23, 2008 | 07:35 PM
conceptualpolymer's Avatar
Originally Posted by benjammy007
the problem i have with my current rotors is that they squeal too much. Anyways I noticed that my rotors have circular groves indented into it and the surface is not flat. Might be why its so noisy every time i brake... Do i have to change my pads as well if i change my rotors? the pads are still quite new... they're hawk hps and ive used them for only about 6 months. Will these pads cause new sets of rotors to squeal and do I need to sand down the pads or something?
Whenever I get pads, I get the "quiet" - type. Hawk makes great pads, but I'm not sure about your particular compound. Have you tried having the rotors turned? Warped rotors will cause the brake pedal to pulsate, but uneven pad deposits on the rotors will result in the same thing.
By the way, not all rotors are equal. PowerSlots are cadmium-plated, which is much more durable than cheapo zinc-washed or unplated rotors that will rust quickly. My PowerSlots are 3 years old and only the pad contact surface rusts when I wash the car. That's the only part of the rotor that is not plated - for obvious reasons.
Booshanky
Sep 3, 2010 03:19 AM
theredsuit
18
Aug 9, 2007 04:48 PM
Fiirkan
Jun 18, 2006 01:29 PM
civic_x
Jun 12, 2006 09:05 PM
mrblackhp
15
Jul 20, 2005 12:59 AM
