Installing Lower Strut Bar
Old Jun 11, 2006 | 03:23 PM
Robertsk8's Avatar
Default Installing Lower Strut Bar
I just recivied a 3 piece sturt bar set from ebay, i have the rear and back strut bars installed but i dont know how to install the lower strut bar. This is on a 2001 civic ex.
Old Jun 12, 2006 | 08:53 AM
Default RE: Installing Lower Strut Bar
ORIGINAL: Robertsk8
front lower or rear lower?
Old Jun 12, 2006 | 10:03 AM
Robertsk8's Avatar
rear lower
Old Jun 12, 2006 | 02:16 PM
It's fairly basic, heres a pic of mine installed. Notice where the ends are attached, there is one bolt at each end. You'll want to lift the back of the car off the ground, pull those two bolts out, put the strut bar brackets on, then re-insert the bolts. Some people have had to use their jack to support the lower control arm from falling down, but I didnt have to. My car is also a 6th gen, and I just realized your's is a 7th. Maybe just try searching the net for "7th gen rear lower bar install" or something to that effect.
EDIT: Forgot the pic
Old Jun 12, 2006 | 03:36 PM
pWnEdU's Avatar
Are yours aluminum or steel? I noticed some on ebay but they were aluminum and I'm not sure if they will be durable enough...
Old Jun 12, 2006 | 04:26 PM
Robertsk8's Avatar
aluminum is fine, its lighter, and guess what airplanes are made out of? steel wieghs a ton and not needed
Old Jun 13, 2006 | 10:01 AM
ORIGINAL: pWnEdU
are you talking to me or Robert?
Mine are CNC Machined BIllet Aluminum, are are perfectly sufficent for a daily driver app
enigma34
Jun 15, 2009 11:08 PM
snosurfa7
Oct 4, 2007 03:26 PM
98BlakCivic
May 14, 2007 04:51 AM
ptw711
15
Nov 13, 2006 11:37 AM
FlipHKD720
Aug 12, 2006 03:28 PM
