question about lower control arm
the innerpart ofmy rear tires are going out very quickly.....the reason is my rear lower arms are kind ofbent........
so i found some after-market lower control arm form ebay......my first question is ......will it fit on my stock suspension...or lower coilover springs necessary
my second question is howto install it???? can i do it myself??????
Your control arms have nothing to do with your springs. Why get aftermarket? Why not OEM?
How did you bend them anyway?
Tire wear is probably from your toe being set incorrectly. When is the last time you had an alignment?
You can install it yourself if you have good tools and you are aware that you'll probably have some seized bolts that will need to be cut out of the car and replaced with new $8 bolts from the dealer.
addiction2bass
Apr 14, 2008 06:28 PM
travjpeter
Sep 3, 2006 11:30 PM
Stimpy
Mar 11, 2006 06:45 PM
