question about lower control arm
Old Dec 18, 2007 | 10:29 PM
nneekk's Avatar
Default question about lower control arm
the innerpart ofmy rear tires are going out very quickly.....the reason is my rear lower arms are kind ofbent........
so i found some after-market lower control arm form ebay......my first question is ......will it fit on my stock suspension...or lower coilover springs necessary
my second question is howto install it???? can i do it myself??????
Old Dec 18, 2007 | 11:09 PM
rice_patrol's Avatar
Default RE: question about lower control arm
yes, it should fit fine. And you can install them yourself with the right tools.
Old Dec 18, 2007 | 11:25 PM
nneekk's Avatar
o thanks man
this shop was goning tocharge me 340 dollars for that
glad that i didnt do it there
Old Dec 19, 2007 | 12:25 AM
ltkenbo's Avatar
$340... rip off!... Yeah some jack stands, a jack, and some sockets, wrenches, should be all you need. No way should you pay a shop at that price.
Old Dec 19, 2007 | 01:22 AM
i might ask... when was the last time you had the car aligned? i just dont see those LCAs bending in the rear.... unless you hit something realy hard... but that could be something as small as just an alignment needed... like your TOE is off which is causing it to wear badly like that...
either way you need to get a alignment done, id get it done first and ask them that if it cannt be aligned due to a bent part if you could come back in 30days after replacing the bent part and have the alignment done again...
when i tried my 94civic is was badly seized adjusters and such, and the guy told me if i bring it back in like 30days with those parts fixed then they would redo the alignment for free. cause lets face it paying twice is stupid... just ask them before they do the work...
simply say YOUR NOT SURE if somethings bent or not BUT if it is and they cannt align the wheels then you could fix and come back later.
worked great for me!
i went thier 3 times.LOL
first time he said front upper ball joint was bad, so i can home replacing it and ran back... then they said that all my rear toe adjusters where froze and id have to fix those took me alot longer to get those BUT then i went back 3rd time and it was done praety good.....
Old Dec 19, 2007 | 03:56 AM
mxs's Avatar
mxs
Your control arms have nothing to do with your springs. Why get aftermarket? Why not OEM?
How did you bend them anyway?
Tire wear is probably from your toe being set incorrectly. When is the last time you had an alignment?
You can install it yourself if you have good tools and you are aware that you'll probably have some seized bolts that will need to be cut out of the car and replaced with new $8 bolts from the dealer.
Old Dec 19, 2007 | 05:29 AM
StifflersMom's Avatar
Cat Fuсker
you'll definitly have siezed bolts...just ask Greddy_civic, he's the latest victim of those
addiction2bass
Apr 14, 2008 06:28 PM
nneekk
Dec 19, 2007 03:54 AM
travjpeter
Sep 3, 2006 11:30 PM
civic_pride
Jun 26, 2006 11:07 PM
Stimpy
Mar 11, 2006 06:45 PM
