Recommended offset?
Old Feb 1, 2008 | 08:08 PM
sboarder97km's Avatar
Default Recommended offset?
I'm trying to get my steelies off and some new rims on. I have no idea what the offset to get. I drive a 94 civic lx
Old Feb 1, 2008 | 08:33 PM
civicexracer's Avatar
Default RE: Recommended offset?
anything from +38 and +42 will be fine
Old Feb 1, 2008 | 11:15 PM
FlipHKD720's Avatar
I've got +40 on my '99 coupe and it looks jsut about perfect
Old Feb 2, 2008 | 11:25 AM
I have +45 on my '94 coupe and they fit fine
Old Feb 3, 2008 | 06:41 AM
Kommando's Avatar
ORIGINAL: sboarder97km
It depends on what width you want.
Assuming stock width of 5.5", with an offset of +38mm, you'd want to measure clearance and see whether you have more on the inner side or outer side of the tires. Cut the front wheels over to full steering lock in both directions while checking this.
I'm guessing that between 38mm and 42mm positive offset would fit most wheels in the correct size range. Maximum tire width would be 205mm, with an overall diameter of around 23.5" for stock speedo/odo accuracy.
I run 6" width rims, with 195mm width tires, at 38mm offset...no rubbing anywhere.
Old Feb 7, 2008 | 07:30 PM
KarTuneMan's Avatar
Kommando had the right idea. You can talk offset all day, but with out knowing wheel width, offset cannot be properly calculated.
My 94 coupe I ran a 17x7 +48. Kosei.
My 06 18x8.5 +40
doodler31
Feb 7, 2007 11:29 AM
dSaint
Mid West
Oct 28, 2006 12:07 AM
ivtec
EK Swaps
Jul 12, 2006 04:58 AM
Chimera02EX
May 2, 2006 04:03 PM
aggie99
May 17, 2004 12:01 AM
