Wheel Becomes Hard to Turn?
Old Dec 13, 2006 | 05:56 PM
TheGodfather's Avatar
Default Wheel Becomes Hard to Turn?
Hello,
Problem:
Turning becomes difficult ( must forcefully turn the wheel, very tight) Happens At low speeds right after or shortly after start up, then goes away. Usually occurs when turning the wheels during parking.
This problem started soon after I reverted back to my stock wheels for winter.
Does any one have an idea of what the problem could be?
Thank You.
Old Dec 13, 2006 | 06:51 PM
ic892003's Avatar
Default RE: Wheel Becomes Hard to Turn?
maybe power steering or ur wheel can be rubbing, not sure just my opinion.
Old Dec 13, 2006 | 10:01 PM
mxs's Avatar
mxs
check your tire pressure
Old Dec 13, 2006 | 10:03 PM
Pete's Avatar
Check power steering fluid, make sure the belt is tight.....maybe the power steering pump is going out.
Old Dec 14, 2006 | 10:52 AM
riceburner700's Avatar
check for power steering leval is full and check for power steering leaks
Old Dec 21, 2006 | 10:16 AM
POLYTHING's Avatar
i had this b4, CHECK YOUR NUTS, lug nug i mean. I did not tight it well and torque! i end up ****ed up all the studs. check the aboves threads...
electricjw
Aug 30, 2014 06:57 AM
Ghettochild_2600
Aug 12, 2013 05:21 AM
jpnolan
Apr 14, 2009 11:11 AM
brid555
Sep 23, 2005 04:19 AM
clutchjunkie
May 30, 2005 02:10 AM
