wheel spacers
Old Dec 7, 2007 | 01:59 PM
07_civiclx_ms's Avatar
Default wheel spacers
worth it? or not. ive got stock steel rims but am looking to get rims eventually. would it be worth it to get spacersnow or just wait until ive got the rims?
Old Dec 7, 2007 | 03:22 PM
Default RE: wheel spacers
By spacers, do you mean those plastic rings that go in aftermarket wheels? I thought they came with most wheels (mine did). Then again, I bought a wheel package (wheels, tires (mounted/balanced), lugs, spacers, etc.)
Old Dec 7, 2007 | 03:34 PM
civicexracer's Avatar
dont buy spacers unless u really have to. just make sure u buy a wheel with the correct offset and u wont have to use spacers.
Old Dec 7, 2007 | 05:35 PM
what are wheel spacers for?
Old Dec 7, 2007 | 05:45 PM
What H&R TRAK+ Wheel Spacers Do:
H&R TRAK+ wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll centre. This simple modification increases lateral stability, which in turn provides improved handling, greater safety and of course, the sleek style you’ve been looking for. Depending on vehicle make and model they are available for most domestic and imported automobiles.
Wheel spacers are also used when a cars such as: Mitsubitsu 3000GT / GTO, Peugeot 406's or some Alfa Romeo's (to name a few) have upgraded brakes, and want to fit aftermarket alloy wheels on, but the larger brake callipers prevents this by coming into contact with the alloy wheel. Other customers of ours needs wheel spacers when they have used brake upgrade kits such as Brembo products. As our fully trained staff deal with such issues on a day to day basis we have unique expert knowledge in this area, unlike other companies who sell wheel spacers. Make sure you deal with a professional knowledgeable company when purchasing alloy wheel spacers.
i say only buy them if u really have to because i've heard of many incidents where bad things happen, mainly due to studs breaking. theres no need to buy spacers if u buy a wheel with the right specs. unless ur looking to build a race car and are looking to improve handling.
Old Dec 8, 2007 | 08:29 AM
ORIGINAL: civicexracer
never thought about the studs breaking, guess i figured a good company would make them strong enough to not break. thanks
Old Dec 8, 2007 | 05:13 PM
KarTuneMan's Avatar
With spacers, the lug nuts have less stud to hang on to....this is the problem. There are also hub centering rings....these are for aftermaket wheels that have a certain bolt pattern, but need to fit a variety of vehicle makes. The center hole (hub hole) is large, and doesn't fit tight on the hub as the O.E. wheel.
There is hub centric, and lug centric. Hub rings are usually used when there is a vibration problem.
Old Dec 11, 2007 | 10:26 PM
projectlowkey's Avatar
i thought about getting a set of eibach wheel spacers a while ago and ended up not buying them. all it does, especially for lowered cars, is give you a wider, more stable stance. it is supposed to improve the cars handling, but at the same time you're puttingmore weight &stress on the wheel studs instead of the struts & springs.usually this results in the spacers breaking. you're better off not getting them. there are plenty of other, more effective,ways to upgrade your suspension.
Old Feb 25, 2008 | 03:29 PM
rytmitz's Avatar
Wheel studs offer the ability to mount a wheel that is not factory supplied to that vehicle. Screw-in studs with a larger than original threaded diameter portion permit mounting of honda wheels with larger diameter holes. Wheel studs of longer length allow the use of wheel spacers to move a wheel further out to compensate for rubbing or backspacing issues or for simple cosmetic purposes.
Old Feb 26, 2008 | 02:52 PM
Kommando's Avatar
Spacers make no sense to me. Just get wheels with the correct offset.
MaximusFunk
Sep 13, 2009 12:33 AM
FastCat
Feb 15, 2008 06:11 AM
redlines4us
Jan 14, 2007 10:15 PM
GotRice?99ex
Jun 10, 2006 11:05 PM
Fibercation.com
Apr 18, 2006 03:39 PM
