91 civic Auto to Manual!!!! HELP
i have a 91 civic auto. its a dx model. i put a D16y8 into it. already did EVERYTHING for the conversion to work. turns on great and everything. only thing is i want to convert now to Manual transmission. i have no idea where to start with this.
my number one question is HOW MUCH am i looking at for the whole conversion?
and from there i just need to know what parts do i need. i have a mechanic doing it for me just want to get the parts myself.
Any Help would be great. Thanks
You will need:
Manual ECU
Clutch fluid reservoir
Clutch master cylinder
Hard lines
Clutch slave cylinder
5 speed tranny (duh)
Shifter
Shift linkage
Shift boot
Manual pedals (all 3, comes in 2 pieces)
All transmission brackets and mounts from the 5 speed
Manual tranny VSS
Manual startere
Manual tranny flywheel bolts
Clutch
Pressure plate
Flywheel
Minor wire changes
Much of this can be found at a junk yard.
Manual ECU
Hard lines
Shifter
Shift linkage
Shift boot
Manual tranny VSS
Manual startere
Clutch
Pressure plate
Flywheel
Minor wire changes
You will need:
Manual ECU or you can convert your current ecu if not manual already
Shifter
Shift linkage
Shift boot
full clutch pedal assembly and swap brake pedals
Manual tranny VSS- his trans is cable speed sensor its the same just hook up your current speed cable to new trans
Manual starter
Clutch
Pressure plate
Manual Flywheel
Minor wire changes- to make reverse lights to work also your ignition switch wont allow key to come out (because it has the automatic park safety switch) there is a write up on this
Shifter
Shift linkage
Shift boot
Manual starter
Clutch
Pressure plate
Manual Flywheel
the parts list is almost complete. i have relied on my local junkyard for the past few tuning that i have done. although nothing much but still i found the experience better than that of ebay or anything else. and ofcourse a lot cheaper. would be doing major tuning of my 91 civic in a few weeks. hope to put some nice pics or vid here.
twistedone_85
Sep 29, 2008 06:29 PM
xoteddyhxo
Jan 1, 2008 09:14 PM
97dxcoupe
Apr 15, 2007 07:44 PM
Ej1Rider
Aug 16, 2006 01:09 PM
