Axle help
Old Mar 23, 2011 | 12:09 PM
etjohn01's Avatar
Default Axle help
I was putting new struts in the civic and when I looked my axle boot was dislocated. i can not get it back together at all. Is it easy to put back together if i take the axle boot off?
Old Mar 28, 2011 | 04:59 PM
Scott53092's Avatar
If you pull the axle boot back you will see there are 3 "bearings" on the axle, they have to be aligned just right, usually have to have them all to close to their outmost spot (they slide in and out like 1/4") and push it in, it should og in relatively easy, then put the boot back on. You really should reband it I'd assume you don't have the tool or bands, which most people don't. You can do bands with a screwdriver, don't just zip tie it shut.
This actually just happened to me last week. Doing a front strut on a Honda Fit, when I pulled the strut I let the knucle hang which pulled the axle apart. Lucky me it was the passenger side so the axle only goes in the half shaft, so I pulled out the axle and reset it. If it was the driver's side I would've had to pull it from the trans which would've sucked!
Old Mar 29, 2011 | 04:35 AM
etjohn01's Avatar
Yeah it ended up working out good. I went to the parts store and got a new band and got the bearings right in there. Thanks for the help
jfiguer
Mar 10, 2008 08:32 PM
t0wards eternity
Dec 17, 2007 10:09 PM
addiction2bass
Sep 22, 2007 05:54 PM
rgus30
Jun 1, 2006 01:36 AM
all2common
Jul 19, 2005 07:40 PM
