New Driveshafts Are in How Do I install?
Old Jul 7, 2005 | 11:03 AM
93SiHb's Avatar
Default New Driveshafts Are in How Do I install?
Got the new axels for the civic im a total nub on front wheel drive cars and imports in general so what would be the best way to go about installing these new cv driveshafts?
Old Jul 7, 2005 | 11:53 AM
Ballz0034's Avatar
Default RE: New Driveshafts Are in How Do I install?
GO down to advanced or auto zone and pick up a Haynes Repair Manual for your year civic.
it will tell you everything you need to know and then some
Old Jul 7, 2005 | 01:00 PM
315 Customs's Avatar
Jack the front of the car up and rest it on jack stands.
Pull the wheels and unbolt the axle nut (32mm or 1 1/4 inch socket).
Unbolt the castle nut on the lower ball joint.
Using a ball joint seperator, seperate the knuckle from the lower control arm and pull the steering knucle off of the axle and set it off to the side.
Passenger side: Using a pry bar, pry the axle out of the transmission by prying at the axle where it meets the trans.
Driver side: Unbolt the bracket half way up the axle then pull the axle out of the transmission (may or may not need to be pried out)
Installation is reverse of dissasembly.
Need anymore help just let me know.
Old Jul 7, 2005 | 07:28 PM
93SiHb's Avatar
thanx gonna give it a shot on saturday
xmctech
Sep 11, 2006 07:18 PM
edward22
Jun 7, 2006 04:28 PM
mjt84
May 25, 2005 03:19 PM
REGNARTS_
Jan 2, 2005 05:54 PM
Lowrider
Dec 4, 2004 12:29 AM
