Problem wiith the shifter.... HELP
Old Apr 13, 2005 | 11:51 PM
syrusstephens's Avatar
Default RE: Problem wiith the shifter.... HELP
u shift without pressing on the clutch????? this is very bad, as it will wear out on the gears fast. even if ur just taking it out of gear. the clutch is supposed to help release the gears without clashing teeth.
Old Apr 26, 2005 | 10:14 PM
frewcivic's Avatar
if you let your car out of gear with out the clutch while diving the gears it will grind. if their is no force on the gears then it wont grind. examp... While you are sitting with the engine stopped, or while you are in a nutral drive state, not nueatral, were the speed of the gears are equal. the clutch disngaes the trans from the engine it dosnt stop the trans.
Old Apr 27, 2005 | 03:53 PM
jwsimons's Avatar
it is even possible, with practice , to shift gears without clutch by matching rpms, without damage to tranny. way back in the old days they didnot have syncros to match em up, .. so if your putting car in nuetral while slowing and it grind's, tap accelerator, when you are synched it will slip nicely out of gear
Old Apr 27, 2005 | 06:11 PM
StifflersMom's Avatar
Cat Fuсker
In fact if it grinds while you're taking it out of gear you're either 1) accelerating or 2) compression braking
Old May 20, 2005 | 12:44 PM
packman5280's Avatar
motorcycles shift all the time without using the clutch.
As long as the speed of the motor matches the speed of the trans, then you will not grind or wear anything out any faster than normal.
addiction2bass
Mar 28, 2010 11:34 AM
yosvani
Jul 29, 2009 08:18 PM
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
addiction2bass
Dec 25, 2007 10:46 AM
RhysCivic
Jul 31, 2007 06:07 AM
