reverse gear problem
i have a 95 EX and about 90% of the time i put it into reverse, it'll make this loud scratching kinda sound when i put it into gear. after i put it into gear its fine. whenever i put it into anyother gear, it dosnt make that sound. only with reverse. i think its the clutch slipping but if it were, y isnt it doing it with the other gears? is this something i should be worried about and get check out? any help would be nice.
thanks!
thanks!
That's just the synchros. Mine does that too. All you have to do is put it into 1st before you shift into reverse. It's a habit with me now. I dont' even think about it. Another solution would be, since you should put your car in gear when you park it, make that gear reverse.
i believe reverse is the only gear that doens't have synchro's on it in the transmission...u dont relaly need it though, cuz u should be completely stopped when goin into reverse anyways.
well for me it does that noise even from a dead stop when i have the clutch in and the gear all the way in...but i've been doin the 1st gear then putting it into reverse and it hasnt made that noise so i guess ill just do that... thanks for the tip sniper
yeah, i panicked about that when i first got my Civ too, like ^they said just pop it in first before you hit reverse. Or, do what i did, and experiment with different speeds and angles when going into it, there IS a path/speed combination that works 99% of the time.
EnT3RiX
Jan 22, 2007 04:35 PM
HaZe89
Jun 25, 2006 01:05 PM
