powering amp?
Old Jan 20, 2009 | 12:58 PM
soundguy1990's Avatar
Default powering amp?
i have a 800 watt kenwood amp... how do yall run the main power wire from the batterry to the trunk im trying to make it look clean and dont want wires laying all over the place.. thanks
Old Jan 20, 2009 | 01:51 PM
i have a 2005 civic coupe
Old Jan 20, 2009 | 03:51 PM
sorry no experience on a 2005 BUT to make it less noticable just get some cheap black wire loom and simply cover the power wire and put some black electrical tape on the ends. that black loom will look close to stock and you should be able to hide it alot easier! for a few more finishing touches try to route the wire as much as posible around other stock wiring and use some black wire ties to keep the wire inplace. and try to simply find the closest wire loom around the battery and firewall.
its not to tuff to make it look like it belongs. just afew touches can make a big difference!
Old Jan 20, 2009 | 06:09 PM
kanarrjl's Avatar
do what addiction2bass said and put the loom on the wire then make sure that you route the wire thru the firewall then under the carpet to get your hands under there you should be able to pop the door sills up and off then lift on the carpet just be careful not to break anything then just find the easiest way to get it into the trunk
Rhino40
Jan 14, 2009 09:03 AM
mill$civic
Mar 17, 2007 07:53 PM
FlipHKD720
Jul 25, 2006 07:51 PM
taintedsaint
Apr 16, 2006 01:37 PM
ptw711
Mar 9, 2006 03:27 PM
