Ok Need some sensor advice
Old Nov 19, 2008 | 06:46 PM
subnet76's Avatar
Default Ok Need some sensor advice
I have taken it off the motor and shorted the leads. My gauge jumps up to HOT. So its not the gauge. BUt what is the part not working here??
Also my abs light stay on, I just replaced the axls on each side. Everything is hooked up but its not engaging. whats up?
Old Nov 19, 2008 | 06:51 PM
The one wire temperature sending unit under the distributor needs to be replaced.
Old Nov 19, 2008 | 06:53 PM
Did you install ABS compatible axles?
Old Nov 21, 2008 | 11:06 AM
subnet76's Avatar
Yes, I make sure of it. One day since then the abs almost worked. My light did not come on. And when i would make a normal stop I could here some clicking and the brake petal would move a bit. But that has not happen again. It started to work but, it wasn't right.
Old Nov 22, 2008 | 08:02 AM
Pull the ABS code. It's probably a wheel sensor and the code will tell you which one. The sensor could have been damaged while changing the axle.
The ABS should not be doing anything during normal stops, only on stops so hard that the wheels would skid on a non-ABS car.
Old Nov 23, 2008 | 08:05 PM
subnet76's Avatar
I do know that it did it before i changed the axles. The car sat for a few years. Im guessing its the sensor on the axle/wheel as well.
Old Nov 23, 2008 | 08:09 PM
What year Civic?
Old Nov 23, 2008 | 08:11 PM
subnet76's Avatar
What year Civic?
1992 ex
Old Nov 23, 2008 | 08:17 PM
The diagrams below were taken from the 92-95 Civic service manual, which can be downloaded at the link in my signature.
boobeyes
Jan 20, 2012 12:51 PM
Ford
Aug 12, 2005 04:46 PM
fastman90
Apr 15, 2005 01:48 PM
laxmanmatt21
Mar 13, 2005 08:41 PM
sureg5062
Aug 21, 2004 02:39 AM
