Question about a ground
Old Feb 12, 2011 | 05:15 PM
xnick101's Avatar
Default Question about a ground
Im new to wiring so please dont be rude! Okay so this is the wire harness for my pioneer head unit. I want to know if that is a ground? And if it is..isnt the top missing or is it supposed to be like that?
Old Feb 12, 2011 | 05:19 PM
That's a ground wire, yes. It's meant for you to like... slightly loosen a random bolt, slide that under, then tighten it back down.
Old Feb 12, 2011 | 06:22 PM
Superfly's Avatar
^ that. Make sure to scratch up the metal so it's nice and shiny and bare before you screw down the ground
Old Feb 12, 2011 | 08:17 PM
xnick101's Avatar
I already have a ground for my 12 volt adapter..can i just add this to that or is it one ground to one bolt?
Old Feb 14, 2011 | 02:51 PM
Superfly's Avatar
Add it. It shouldn't matter
Old Feb 15, 2011 | 06:52 AM
Newfiedan's Avatar
I always connect that to the stereo adapter plug you have, it should be fine that way, mind you running it to chassis will not hurt anything its just easier to prewire it the way I do it.
Old Mar 15, 2011 | 10:28 AM
alex l.'s Avatar
I find tec screws work best for grounding
Old Apr 3, 2011 | 07:32 AM
Akihrio's Avatar
Most unpainted bolts that go into the frame or are attached to steel pieces that attach to the frame will work fine. I'm pretty sure you could even bolt it into the steel supports that your centre console bolts to since it's attached to the frame.
gsumano
Jul 5, 2008 08:24 PM
addiction2bass
May 29, 2008 04:12 PM
addiction2bass
17
May 16, 2008 06:29 PM
addiction2bass
22
Apr 26, 2008 06:06 AM
khanselman
Aug 18, 2006 02:02 PM
