I just have to know!!HELP!!! I need a genius
Old Jan 31, 2008 | 02:15 PM
bakertime's Avatar
Default RE: I just have to know!!HELP!!! I need a genius
The intake mani and TB you've got are probabaly changing your powerband. Depending on the runner length, and other factors, you're band could be shifted slightly higher then his. It may be killing you on your launch, resulting in less power in the lower RPM's. Did you guys every run side by side? Where did he pass you?
Old Jan 31, 2008 | 02:55 PM
Mylittlecivic's Avatar
ORIGINAL: bakertime
Good god i think you may be right! hmm didnt think about that but the the power band may have taken a more drastic hurtin then i thought it would. guess ill have to get me another head and start workin on it lol. I think ur the genius i was lookin for. hope thats all it was.
Hmm i got to thinking about that and I was keeping up with v8's until i had to shift into 3rd. thats where everyone kills me. hmmm[sm=helpout.gif][sm=partyparty.gif]
Old Jan 31, 2008 | 05:46 PM
bakertime's Avatar
Yeah, just remember bigger isn't always better when it comes to Intake and Exhuast. No one option is "better" it's just different. Also good to remember that Honda are tuned for low end power, where a daily driven car spends most of it's life. Hence the small exhuast, etc.
Old Jan 31, 2008 | 07:16 PM
so what do you think the best thing would be to do. just get another head and work on it with like valves cam springs and stuff then once its all together getting it tuned?
Old Jan 31, 2008 | 07:23 PM
jamned's Avatar
The first thing I'd do is let your friend make the same run with your car a few times. Maybe you could also make a few runs with his car. If the difference in times is still consistent, then I'd think that there was a difference with the cars.
Old Jan 31, 2008 | 07:57 PM
bakertime's Avatar
ORIGINAL: jamned
Yeah, definitely a good idea. As for changes, if you decide to, maybe just go back to your stock TB and IM, or just try one of them. You're best bet is to just try things. A dyno is a great place for research, but not cheap.
Old Feb 1, 2008 | 01:33 PM
So i just found out my buddy had is getting a different egnine put in his car. well 1300 buck for a built d16z6 with stage one head and different rods and stuff. think they are eagle. with gsr tranny. I keep asking him to let me see if its chipped or somthing. lol. So i guess ill never know. o well.
By the way he did drive it and he ran 15.8
Old Feb 3, 2008 | 01:51 PM
branx's Avatar
Member
it is possible that his engine is simply better condition then yours, better compression, timing, alot of influences
Old Feb 3, 2008 | 08:13 PM
jamned's Avatar
I can second what branx said. If you have valves fouled with heavy carbon deposits, that'll kill your compression. Clogged injectors would affect fuel delivery. A catalytic converter can also clog, which would add further restriction to your exhaust. I can't think of other causes, but like branx said, there could be a lot.
I8UMUP
Jul 30, 2008 04:14 PM
windcalmer
Nov 18, 2006 09:00 AM
Colby Day
13
Oct 1, 2006 10:10 PM
Remmy
Nov 23, 2005 11:34 PM
