injectors not firing
Old Aug 27, 2007 | 12:11 PM
honda_kid2's Avatar
Default injectors not firing
i have a 1988 honda civic dx... with a 1999 civic si motor . " 1.6 vtec" B16
i just put the motor back together yesterday .. and no it cranks fine but will not run .. . if i spray starting fluid in the throttle body it will run for a second then die ....i have pressure to the fuel rail ... but the injectors arent firing ...i know there not clogged ... someone mentioned some kind of relay under the dash that deals with that ... but im not sure what to check ..
any help would be a huge help ... thanks DUSTIN
Old Aug 27, 2007 | 12:15 PM
Mr Mobsta Man's Avatar
Default RE: injectors not firing
I know it sounds stupid but did you make sure all your plugs/harnesses are all plugged in completly? Why did you have the engine apart? Are you using the same ecu?
Old Aug 31, 2007 | 04:00 AM
GreenHatch's Avatar
Check out the relay under the dashboard as suggested. Had the same recent case with the fuel injectors. Replacing the relay fixed it.
Old Aug 31, 2007 | 06:03 AM
Littlehag's Avatar
Another thing to check is your ecu. Is it the same ecu you had in the car from 88? Your ecu has to match up with your engine. In most cases.
Old Sep 3, 2007 | 01:06 AM
jwsimons's Avatar
im confused! is this a fresh swap???
Old Sep 3, 2007 | 07:39 PM
honda_kid2's Avatar
no this engine has been in here for a long time and running,
srdaniel
Nov 8, 2011 09:02 PM
jusplayn85
12
Mar 12, 2006 09:39 AM
joey
Oct 30, 2005 10:26 AM
djglovehead
Apr 24, 2005 01:38 AM
cdubscivic
Jun 20, 2004 06:10 PM
