B18A1 Build Up
Old Feb 11, 2007 | 09:03 PM
  #21
WTB9295Hatch's Avatar
Default RE: B18A1 Build Up
81 mm is the stock bore correct? I'd really like to stay stock bore just to stay axzy from the hasssel of oversized pistons and piston rings. Besides if I stay at stock bore then if I ever do blow the engine I can go back in and have the cylinders rebored to .030 over. If I do it now then I want be able to do that. I'll just be SOL.
Old Feb 12, 2007 | 10:01 PM
  #22
Kedawei's Avatar
OS pistons aren't going to cost you any extra, forged pistons are basically custom parts anyway. And if something does happen you can always bore to 84.25 or 84.5mm, which are the same service limits as the 81mm sleeves will be.
Again, there is no reason not to.
Old May 16, 2007 | 04:35 AM
  #23
mclane93's Avatar
YOU MUST sleeve your b series blocks if you are going past 14 psi of boost!!!!! dont take a chance. hondatuning.com and sport compact magazine will both tell you this. I am doing the same **** as you are!
turbo speeder
Jan 28, 2009 03:57 PM
RCJr9186
May 30, 2007 09:07 AM
alteredimages
Mar 11, 2007 10:54 PM
SovXietday
Feb 12, 2007 11:55 PM
HondaSuperman
May 22, 2005 01:07 AM
