H22 SWAP WITH T3/T4 TURBO KIT HELP
Old Sep 5, 2006 | 10:07 PM
OSBURN's Avatar
Default H22 SWAP WITH T3/T4 TURBO KIT HELP
I've got $6000 and am about to order an H22 and boost it with a T3/T4 turbo kit. Any other modifications need to be done as in a clutch, tranny etc. Or can I pull it off with just the stock H22 and the turbo kit? Help ASAP
Old Sep 5, 2006 | 10:17 PM
ef4life's Avatar
Default RE: H22 SWAP WITH T3/T4 TURBO KIT HELP
definatley upgrade the clutch to a stronger one. also you should do a compression test before boosting because h22's are good but somewhat fragile engines to boost. definatley get a full engine management system like hondata or neptune and a good dyno tune regardless of what you do
Old Sep 5, 2006 | 10:33 PM
OSBURN's Avatar
thanks man. but what about the internals on it. i read somewhere that you cant boost it without changing all the internals.
Old Sep 6, 2006 | 03:11 PM
Nail I3unny's Avatar
depending on the turbo...you can boost 6-8 psi safely on stock internals. a good rule of thumb is honda internals can safely handle twice the power they have stock and in some instances more than that.
ps Exedy stg2 Clutch.
Old Sep 6, 2006 | 10:10 PM
OSBURN's Avatar
i want this thing running safe, so what would i have to do to put a T3/T4 in it. How much would it cost to change the internals around? and what all would i have to get?
NCivic23
May 3, 2008 06:53 AM
stevenmize
EG Swaps
16
Nov 15, 2007 08:34 PM
i30stmi
Sep 3, 2007 07:49 PM
longears
Jul 3, 2007 08:10 AM
justin
EK Swaps
Nov 14, 2006 08:22 PM
