Removing rear window
Old Aug 3, 2009 | 03:00 PM
burnindesirez02's Avatar
Default Removing rear window
How hard is it to remove the rear window? just as simple as removing the weather stripping? i need to fix my defroster grid and it would be easier with the window out...thanks
Old Aug 3, 2009 | 03:35 PM
Pretty sure that you remove the weatherstripping, and under that are some clips. There should also be some sort of sealant where the glass rests.
Old Aug 3, 2009 | 05:26 PM
ya IMO dont mess with it.. just try to fit the defrosters with it still on the car!
that or if you have insurance and dont mind using it.... then smash out your back window and have them replace it with a new rear window.
they have those little fix kits but if you have window tint on the back window well its gonna have to be removed so you can find the bad spots to fix them. but its still not going to be easy to fix them! i had a problem with my old 99 civic with the rear defroster wire terminal broke off the rear window glass itself which was VERY HARD to get a wire to solder onto it and i still verly got it on there. so even if your just unplugging the defroster terminal then be very carefull when unplugging those 2 terminals!
Old Aug 4, 2009 | 12:19 AM
yea...i know they have kits for it but my grid is broken on every line...so i have to fix alot of grids...and it used to have tint but the guy i bought the car from removed it so thats probly why it happened...thank
99lx
Dec 29, 2010 04:37 PM
invertedflight
Mar 28, 2008 11:53 AM
hexumjunkie
Mar 20, 2008 07:16 AM
Vadagar
Jun 5, 2006 07:56 AM
corye03
Feb 26, 2005 09:08 PM
