87 civic si starts then dies
Old Jan 8, 2009 | 05:56 PM
Originally Posted by Deadhonda
ok so what ill do is ill pull the one out of my brothers car he has the same ECU in his. but i am not really understanding the whole powersupply check
could you explanine?
It's very convenient to have access to a good ECU!
The diagram is a troubleshooting flowchart. The top part shows two different voltmeter tests to do on connector B of the ECU. The lower part shows what the problem may be depending on whether the voltmeter tests are good (o.k.) or bad (NOT).
Old Jan 13, 2009 | 03:27 PM
Deadhonda's Avatar
hey ron i pulled the ECU out of my car and put it into my brothers can and gess what his car is now doing the same thing as mine so i know that it is MY ECU
any ideas on where i can get a good one
Thanks for you help
Joe
Old Jan 13, 2009 | 03:31 PM
Great, you pinpointed the problem. That's a big step. Try to find a replacement ECU at a salvage yard or on eBay.
Old Jan 13, 2009 | 03:35 PM
Deadhonda's Avatar
ok i am kinda leary on getting a used on cause they are kinda hi and i am guessing that u cant get a neew one anymore
Old Jan 13, 2009 | 03:40 PM
Check here for a new ECU:
http://www.hondaautomotiveparts.com/...ry4=&catcgry5=
Old Jan 13, 2009 | 04:02 PM
Deadhonda's Avatar
hey might be a dumb question but will a newer year ECU fit in a 87?
Old Jan 13, 2009 | 04:17 PM
Justin13's Avatar
Banned
RonJ is a really good source of info. i vote he should be a mod
Old Jan 13, 2009 | 04:25 PM
I appreciate the thought, but I'd be a really mean mod. Best for me to stay a regular old member.
Old Jan 14, 2009 | 02:31 PM
Deadhonda's Avatar
Yes ron you have been a great help
But got one more question i the Ecu i pulle out is #37820-PE7-6820
i called a import place and they said that i have the wrong one and that i need a PE1 modle
what can you tell me about this?
Old Jan 14, 2009 | 05:32 PM
At this link: http://honda-ecu.com/partindex/ecuoem5.htm
I found both PE1 and PE7 ECUs that seemed compatible with a 1987 CRX 1.5L fuel injected Si.
Therefore, in my opinion, you should purchase the PE7 ECU that matches the current one in your car.
scotta
May 17, 2015 05:36 AM
scotta
Apr 17, 2015 12:11 PM
drewrussell2011
May 17, 2014 07:57 PM
therodskuuts
Dec 22, 2008 01:52 PM
peptan
Apr 28, 2005 02:16 PM
