93 civic dx wont start
Old Aug 20, 2009 | 02:24 PM
  #31
wjd03's Avatar
no continuity on clutch safety switch either
Old Aug 20, 2009 | 02:25 PM
  #32
wjd03's Avatar
set to ohms
Old Aug 20, 2009 | 02:27 PM
  #33
wjd03's Avatar
in post 29 i should have said bat to black w/ white stripe
Old Aug 20, 2009 | 02:31 PM
  #34
wjd03's Avatar
I have tested the connections and found a loss of continuity on switch in 2 and 3 position but the one we wanted most , i found a loss of continuity between the batt and blacck/ white stripe
Old Aug 20, 2009 | 02:33 PM
  #35
Originally Posted by wjd03
set to ohms
What Ohm scale? With the multimeter set to Ohms, then continuity would be indicated by a low Ohm value such as 1 Ohm or less. If this is your measurement, then there is continuity. Verify that you are making the right reading by touching the two meter probes together. What is the Ohm reading?
  #36
wjd03's Avatar
i hope this thread helps someone in the future
Old Aug 20, 2009 | 02:35 PM
  #37
wjd03's Avatar
set @ 2000 ohms w/out touching anything it reads 1 when i touch the leads togather, it goes to 0
  #38
...but the one we wanted most , i found a loss of continuity between the batt and blacck/ white stripe
If this is correct, then you need to replace the ignition switch. As this job is not easy, make sure to triple check your Ohm/continuity measurements.
Old Aug 20, 2009 | 02:38 PM
  #39
wjd03's Avatar
ok will do. but according to the checks, it looks like the switch. sometimes the ignition switch faults...even before this prob
Old Aug 20, 2009 | 02:42 PM
  #40
