can't get rid of heater circuit malfunction code
Old Oct 22, 2008 | 12:48 PM
brutekiller787's Avatar
Default can't get rid of heater circuit malfunction code
before you ask. yes i've cleared it many times. yes i've checked the wiring and it's all good. yess i've replaced both the oxygen sensors. it's a 97 lx sedan and i always get that code back and it's really starting to annoy me. any help would be nice
Old Oct 22, 2008 | 01:01 PM
Well, if you are confident that the O2 sensors and wiring are fine, then the ECU may be bad.
Is the CEL code for the primary or secondary O2 sensor? What specific CEL code?
Old Oct 22, 2008 | 03:58 PM
gwl's Avatar
gwl
Are you using aftermarket sensors? If you are, you may want to try a different brand or even Honda sensors.
Old Oct 22, 2008 | 06:26 PM
TheJGB3's Avatar
Old Oct 23, 2008 | 05:52 AM
Check that you have 12 volts at the sensor with the key on. If you don't, something is wrong with the wiring.
Old Oct 28, 2008 | 04:26 PM
RonJ: it the codes for both the primary and secondary heater circuit codes.
gwl: both sensors are bosch.
mk378: where exactly do i put the probes to test that. would the female connector for the o2 sensor be ok?
Old Oct 29, 2008 | 01:21 AM
TheJGB3's Avatar
That is your problem
The owner of http://www.oxygensensors.com specifically told me NEVER TO USE BOSCH O2 sensors on ANY HONDA OR TOYOTA because they DO NOT WORK for some reason (in fact he refuses to sell them). I know that Bosch is a great brand normally, but their O2 sensors for Honda and Toyota just don't seem to cut it.
Your best bet is to replace them with OE style denso, walker, NTK (the O2 sensor division of NGK and who makes the Honda OE ones) or OEM Honda. Anything else will definitely cause issues.
Old Oct 29, 2008 | 04:55 AM
Did you cut and splice wires to install the O2 sensors?
StevenM27
Nov 19, 2011 09:20 PM
brutekiller787
Sep 10, 2008 03:04 PM
n8te81
Jul 8, 2007 03:13 PM
