Clutch chatters when engines warms up!!!
Old Jul 10, 2011 | 10:10 PM
enzo-gti's Avatar
Default Clutch chatters when engines warms up!!!
Hi guys,
I have a weird problem with my transmission (mostly my clutch). Last summer I swap my engine to D15B; i did not change the transmission, but I put in a premium stock clutch. After a couple months, I started to have the clutch chattering problem; anytime I want to go to gear 1 from complete stop I have to go with high rev, otherwise the car would shake so badly. This happens only when car is warm, in the morning everything works perfect. Also this happens for the reverse gear as well, it shakes horribly.
My last mechanic did a horrible job, so I have taken it to a few other mechanic shops, most of them said it is flywheel problem, one of them said it may be your engine swap since the transmission is for 1.6L 1996 Honda civic (stock transmission). He believed that transmission is not a good match for this engine.
Anyways, when the car is cold everything works fine, after a few minutes driving it becomes really bad (the warmers it gets, I have to rev higher)!
Thanks in advance for your responding.
Old Jul 10, 2011 | 10:41 PM
Make sure it's not misfiring. Get in a gear that is somewhat too high (engine turning about 1800-2000 rpm) and alternate between not pressing the gas and flooring it -- without touching the clutch. If the car shakes with heavy throttle at low rpm, it's misfiring, not a clutch problem.
Old Jul 10, 2011 | 11:22 PM
enzo-gti's Avatar
Thanks MK378, all the mechanics and I have checked the possibilities for causing such shake including misfiring, car works perfectly for good first 10-20 min when it is cold, after that shakes only when i want to from complete stop to first gear. other gears work completely fine.
Old Jul 11, 2011 | 12:26 PM
Worn clutch or clutch contaminated with oil
Old Jul 21, 2011 | 07:58 PM
enzo-gti's Avatar
The problem is fixed now, Apparently my last mechanic did a ****ty job during putting on the new clutch. The flywheel had to be resurfaced which it was not. I had to change the whole clutch system and resurface the flywheel and it did cost me $570 (in Toronto, Canada).
Thanks for all your replies!
Guitardude_15
EK Swaps
Aug 8, 2008 04:27 PM
Oldvic
17
Sep 17, 2007 08:14 AM
D16Punk
May 31, 2007 12:53 PM
gunner11
12
Jan 27, 2005 11:31 PM
gunner11
Jan 21, 2005 08:34 PM
