clutch probs
Old Feb 1, 2006 | 04:17 PM
97CivicEX's Avatar
Default RE: clutch probs
ORIGINAL: sacicons
actually, the ignition could be going out too, and the clutch thing was just a coincidence.
I agree, this is more likely since I have seen many ignitions(where you stick the key in) go bad and be intermitent.
Old Feb 1, 2006 | 04:42 PM
joey's Avatar
yea, now that i think of it, a guy in my class had that same problem. he'd turn his key and get nothin but if he tried er a few times it'd work. i'd say that's more likely than the safety switch. i don't think they're known to go.
Old Feb 2, 2006 | 08:07 PM
neon_killer's Avatar
ya in the starting system theres like a gate in the wiring and if the clutch pedal isn't pushed in all the way the the gate doesn't close and circuit connect to get power to the starter the same way with automatics if the not in park or nuetral then you can't start then cause that gate ins't closeing so you switch that the pedal pushes in probably isn't being pushed in all the way
Old Sep 7, 2008 | 04:13 PM
evoncivic's Avatar
how do your replace the neutral safety switch/neutral start switch
Old Sep 7, 2008 | 06:07 PM
What year Civic? it's at the top of the clutch pedal.
xjbmx
Oct 16, 2005 06:03 PM
Squeaks47
Oct 4, 2005 04:17 PM
96coupe_cj
Sep 23, 2005 12:30 PM
finalimpact
May 24, 2005 07:52 PM
Amanda
Feb 22, 2005 12:39 PM
