help running rich
Old Nov 17, 2008 | 02:01 PM
  #41
LtShackelford's Avatar
belt was a bit wet, it stopped its on there pretty good
Old Nov 17, 2008 | 04:28 PM
  #42
it started squeeling again the belt is on there tight what could it be it doesnt squeel all the time its usually only before 2000 rpm and sometimes at idle
Old Nov 17, 2008 | 05:02 PM
  #43
You probably need new drive belts or possibly a new idler pulley.
Old Nov 17, 2008 | 05:31 PM
  #44
Remove all the external belts and spin each accessory pulley by hand. They should be almost silent. If you don't find anything obvious, start the engine with the belts off. It could still make squeaking noise from that end, meaning it is something related to the timing belt such as the water pump or tension roller.
azwethinkweiz
Mar 22, 2010 08:12 PM
slow2_2
May 13, 2008 06:51 PM
davidb123
Mar 2, 2008 12:17 PM
scottdh20
Nov 24, 2007 07:50 PM
JDMracer00
Jul 6, 2005 04:11 PM
