hole in gas tank?
Old Apr 11, 2007 | 12:46 PM
Live_4it's Avatar
Default hole in gas tank?
My friend suspects that his car has a hole in his gas tank. whenever it's over half of a tank it leaks gas around the left rear tire. I suggest that he finds one off ebay but I dunno, are there any methods of fixing it? Would it be a good idea to run some fuel injector cleaner through it or would that make the leak worse?
Old Apr 11, 2007 | 08:52 PM
classiccarsrule85's Avatar
Default RE: hole in gas tank?
I would like to know this also i have the same problem on my volvo turbo ......i dont think however its a hole in the tank maybe filler neck?
Old Apr 11, 2007 | 09:52 PM
windcalmer's Avatar
They do make a puddy epoxy that will seal it up. I would say if you have the money, have the gas tank and filler neck changed out for a new one though.
Here is the first one i found on google. HERE
And before someone says it, no you cannot weld it back up without having the tank cleaned and flushed. Big time pain in the @$$!!!!!!!!!
Old Apr 11, 2007 | 11:05 PM
Live_4it's Avatar
cool the epoxy puddy looks like the right stuff, it's probably a temporary fix though but I'll definitely tell him about that.
What about using fuel injector cleaner? would it be a better idea to wait till the leak gets fixed first?
Old Apr 11, 2007 | 11:56 PM
windcalmer's Avatar
I wouldn't run it till you get a new tank. If there is a hole in the tank, then water has gotten into the gas and thats not gonna be good for the motor.
fasterem
Jul 29, 2011 05:49 PM
Love2drive
Jul 6, 2011 06:20 AM
edwinss4
Dec 6, 2010 06:10 PM
Sprite_15
Nov 6, 2007 04:18 PM
CarmineD187
Jun 12, 2006 10:19 PM
