idle and start up
idle and start up
i have a 96 civic with a ls-v swap and it has a hard time starting and the idle sits at like 1500 when it get warm i have tried cleaning the IAC messing with the idle screw and i am just out of ideas so if anybody knows anything please help
The test to check for air flow through the side holes is important. Once warmed up, the FITV one should be completely shut off, and you should be able to stall out the engine by blocking the IACV / air screw one. Excessive air getting into the intake manifold by any undesired path will increase the idle speed. Check also for missing vacuum hoses or a leak in the brake booster.
David_S
10-24-2013 10:06 AM
MaximusFunk
03-13-2012 08:26 PM
honvic
09-02-2011 09:49 PM
95' 1.6dx
04-25-2010 12:26 PM
draco880
09-06-2008 05:26 PM
