My Civic wont start Please Help
ORIGINAL: Kolhoznik
I think its still worth checking voltage at the pump...could be two separate problems. Although very likely it is the ECU...if I knew how to check it...
try swapping ECUs with a friend and see if that fixes it:-D
The easiest way to check the pump is to turn the key on but dont crank it. you should hear the pump prime up in the rear of the car. BZZZZZZZ.
If you don't hear that, then for some reason or another, the pump isnt working. At this point def check for voltage. If it is getting it, but wont go, its the pump itself, if no voltage, try to figure out why not.
I'm voting pump on this one, even with a clogged filter you should get SOME gas.
9T6EX
Mar 23, 2012 03:44 PM
3daddict
Nov 10, 2011 10:39 AM
CustomCivicClubCCC
May 23, 2011 12:35 PM
bmelloh
May 16, 2009 08:01 PM
