Odd noises
Old May 12, 2008 | 05:46 AM
CerialPhreak's Avatar
Default Odd noises
Hey guys,
Been noticing two new noises my 03 si has developed.
1. At about 40 mph the right front side of my car starts to hum, its constant, and isnt affected by me putting the clutch in (I'm thinking its a wheel bearing?)
2. This morning when i started the car to go to work, i took the clutch out in neutral and noticed a buzzing, this stopped when i put the clutch in. It wasnt loud by any means, and could only hear it with the stereo off. The closest sound i could equate it to would be like change rattling (which there isnt any in my car).
Any ideas?
Old May 12, 2008 | 09:06 AM
hatch46580's Avatar
Default RE: Odd noises
cat shield
Old May 15, 2008 | 04:49 AM
cachenut's Avatar
You might check the trans fluid levels to be sure there is the right amount in there. Trans take a beating and I tend to break them in Hondas. If all it does is make a litle noise then you are lucky. Hard shifting hurts the little things.
Buzz at 40 is perhaps tire, bearing or rotor related. Check bearing and swap tire to left to see if it moves or goes away.
Might be air related as in lose flap or plastic somethin that buzzes in the wind.
Old May 22, 2008 | 12:18 PM
DORIS709's Avatar
how much should a cat shield cost? how long can the rattling go on without it causing damage?
Old May 22, 2008 | 12:38 PM
The noise that goes away when you push the clutch in is most likely from inside the transmission. Check the fluid level, if OK you can ignore the noise until it gets louder.
Rattling from the heat shield is usually loud enough to hear with the radio on unless it's turned way up. You can just let it rattle until you get tired of hearing it, there won't be any further damage.
Old May 22, 2008 | 12:52 PM
enigma34's Avatar
The spring's for the my muffler's, flex system on my civic rattle.. im going to like shove something in the spring.
Old May 23, 2008 | 05:06 AM
oh2civic's Avatar
the noise with the clutch is deffinately transmission...i just had this problem and no one could diagnose it...even the dealer....deffinately make sure trans fluid is toped off....i had to get a new transmission cause the problem went so long untreated one day my car started poppin out of 5th
Rabbit
Oct 12, 2011 09:38 AM
nemo
12
Dec 4, 2005 01:20 AM
toby
Jun 19, 2005 10:11 PM
nwhite82
Dec 5, 2004 04:53 PM
superflycivic
Sep 24, 2004 01:41 PM
