Power window trouble
Old Sep 13, 2008 | 08:16 PM
Lightsped's Avatar
Question Power window trouble
The car is a 00 Civic SI. When I raise my window it goes up fine, but when it gets to the top it doesn't stop. By that I mean I have to stop pressing the button at just the right time. If I don't stop pressing the button, the window will very loudly pop back down about a 1/4" and go back up, and back down a 1/4". It will continue doing this as long as the button that raises the window is pressed.
Not long ago, this window came off the track. I took the panel off, lubed the tracks, and it worked fine until now.
I guess what I need to find out is how do the windows know to stop when they get to their upmost raised position?
Old Sep 14, 2008 | 05:04 AM
Sounds like the regulator gear is stripped. This is the gear that engages the one on the motor. When it gets to the last tooth it skips, causing the window to jump up and down.
Old Sep 15, 2008 | 07:32 AM
Old Sep 15, 2008 | 11:37 AM
Lightsped's Avatar
Forty04, I saw some of your old posts about your window a while back. I saw that you had some pics, and video, but all the links were broken. From what you described, it sounded like you had a similar problem to my window....
Old Sep 17, 2008 | 05:48 AM
I just redid the whole write up, pics/vids are up and running now.
Good luck!
CatsnotCars
Jan 28, 2015 12:24 PM
HebertJoshua
Apr 27, 2011 07:59 AM
Kenny-g
Apr 26, 2010 04:20 AM
eisenberg
Feb 14, 2010 07:14 PM
AGibney
Dec 29, 2009 05:59 PM
