Replacing my Engine
Old Aug 21, 2008 | 03:23 AM
Drifter518's Avatar
Default Replacing my Engine
Hey Everyone,
I have a 97 EX where I just blew my engine, basically the guy who sold it to me lied and told me the timing belt was changed and it wasn't so it went and I ended up throwing a rod threw my block.
I have been looking for a D16y8 engine which is getting really hard to find, not to mention I live in VT so shipping kills me too.
I was just recently told that I can use any block and just get a Y8 head and put it on the block. Is this true?? Can any civic block be used?? I figured the mounting would be different, but I don't know a lot about it.
Thanks
Old Aug 21, 2008 | 05:05 AM
As long as the engine code on the block says D16xx, it'll work. The xx can be a Y7, Y8, Z6, etc.
Old Aug 21, 2008 | 06:16 AM
Did the timing belt actually fail? Usually a bad timing belt will mess up the valves, but throwing a rod is not common. Take your head off and examine the valves. If they're not cracked or bent you should be able to re-use your head on another block. As itinerant said, any D series 1600 cc block will work.
Old Aug 21, 2008 | 06:18 AM
Drifter518's Avatar
Default thanks
That is exactly what I was wondering, I say a D16y7 and was wondering if it will work. This will make my engine search so much easier.
thank you again
Old Aug 21, 2008 | 08:33 AM
Drifter518's Avatar
So I was looking at a 94 civic, where the seller says it has a 1.6L in it, problem is it's a DX, could I buy that engine and just switch the header for my 97 ex??
BigDadE84
Sep 7, 2008 06:37 PM
Civic Si 00
Nov 30, 2007 01:39 PM
jakeolas
19
Nov 27, 2007 01:58 PM
snosurfa7
Jan 8, 2007 09:52 PM
hueyproductions
Jan 6, 2005 04:08 PM
