Boost is Gone
Old Aug 30, 2007 | 09:39 PM
bcrichguitars's Avatar
Default Boost is Gone
I was driving today in boost about 7 psi and then a few minutes later I realized I couldn't really hear my blow off valve. I checked my boost controller and boost guages and it was only doing about 1.5psi.
My boost really just went away, even with the boost controller off it only does like 1 psi and the wastegate spring is a 3psi spring and it used to go that high before today.
What caused this? Did I ruine a part of my setup or is my boost leaking from somewhere? I thought maybe it was just my boost controller but it still doesnt hit over 2 psi with the boost controller off anymore.
Should I bring it to a mechanic shop? Would this be a lot of labour to find the problem at a shop that deals with turbos and performance
I just dont know what to do so anything is appreciated.
Thanks
Old Aug 31, 2007 | 02:22 AM
Default RE: Boost is Gone
look for leaks?
sounds like a blown coupler
Old Aug 31, 2007 | 06:08 AM
RCJr9186's Avatar
boost leak somewhere. check all of your couplers... something that dramatic it's gotta be a big leak so it shouldn't be to hard to find.
Old Aug 31, 2007 | 07:55 AM
K ill try and find it again. Just kinda dissapointed I can't run boost now and I have no extra money to bring it anywhere to be looked at.
EDIT: Found the boost leak, looks like a loose clamp on the coupler, ill just tighten it and see if it fixes it.
Old Aug 31, 2007 | 10:14 AM
So I ended up tightening it and realizing the pipe wasn't fully in the coupler on one side. So I had to loosen it again and i'm about to tighten it, it's in such a small space for a wrench it will probably take me 20-30 minutes just to tighten this stupid clamp.
Old Aug 31, 2007 | 10:25 AM
ORIGINAL: bcrichguitars
lol, I bet I know right where it blew off. I had to perform the same fix in a gas station parking lot, during a rain/sleet storm in January (in Michigan none the less), so I think You'll be okay
Old Aug 31, 2007 | 10:53 AM
YA I'll be ok but i'm still working on it. I wish there was more space, I just got my HID's in yesterday and the ballast is kind of in the way but I don't want to have to take it off and put it back on too lol. I'll just keep tightening the clamp hopefully i'll be done soon lol.
Old Aug 31, 2007 | 11:30 AM
Seems to be fixed. Thanks
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
elfreaky70363
ED-EF Swaps
Jun 13, 2005 08:53 AM
Kappa22
Feb 19, 2005 10:02 PM
red_sleeper
21
Jan 13, 2005 08:58 PM
