car higher after lowering
Old Aug 14, 2007 | 07:01 PM
burgernuds's Avatar
Default car higher after lowering
a professional shop installed tein H techs for me but after they jacked it down the car looked higher!! they decided to re order S techs for me, but now that I've driven it home i've noticed that it is actually lower than when just raised down from the jack and the H techs seem to be working with the drop that they were advertised for. though very disappointing (still a big gap)........ Is this common? There were 4-5 guys at the shop that didn't know why. I don't think its an illusion or anything like that, it was clearly higher when I briefly glimpsed at it.
Old Aug 14, 2007 | 07:33 PM
mxs's Avatar
mxs
Default RE: car higher after lowering
They need a few days to settle, that should include some spirited driving, not just sitting in the driveway.
They won't settle much though, H-techs are hardly a drop at all
Old Aug 14, 2007 | 08:49 PM
burgernuds's Avatar
So this sounds normal to you? Those guysseem like they have a lot of experience butthey freaked out when unjacked it looked higher! They blamed it on Tein malfunction or factory screw up andnot installation. But when I drove it home it looked fine, a lot lower than when just unjacked.
Is that normal? Anything else they could have done wrong? And ya H techs suck big time. Going to redo it with S tecs
Old Aug 15, 2007 | 09:21 AM
riceburner700's Avatar
the springs probably twisted and settled into the right spot which put them lower and were they were sappost to be. do you have any before and after pics?
Old Aug 15, 2007 | 09:44 AM
My04Civic's Avatar
Administrator
give it a few days, like MXS said, the h-techs are not a huge drop but it should be noticable when they settle
Old Aug 15, 2007 | 12:16 PM
burgernuds's Avatar
no i dont have any barely unjacked pictures as they took me to the area and i just glimpsed at it and it was super ugly and high, higher than factory. When I drove home they seemed to have settled. heres what it looks like now, obviously lower than factory stock. Im just worried they didnt install it right/something busted/broke causing the car to then lower. Also is it normal to hear the springs a bit during breaking after starting up? when i first drove out of my drive way today i hearda lot noises but then after about 10 minutes it was fine...
Old Aug 17, 2007 | 12:13 PM
Kommando's Avatar
ORIGINAL: burgernuds
Your stock springs could have been sagged too. Give it a few days of spirited driving for the new springsto settle a bit. I'd also check to make sure everything is lubed and properly torqued. Learn how to do this kind of work yourself. Most shops are clueless/careless when it comes to modded vehicles. They aren't going to put the same effort into a car that a clued-inowner would.
Old Aug 18, 2007 | 01:10 PM
burgernuds's Avatar
so are you saying that its normal for new installed springs to look higher and then "settle" down to their desired height after some driving?
I trust this shop a lot! They are an branch extension of Autobacs and I wouldn't know what I'm looking at it if I poke my head under my car....
Old Aug 20, 2007 | 06:19 PM
Kommando's Avatar
Definitely. You never see older springs that are higher than they started at, do you?
Old Aug 21, 2007 | 08:31 AM
burgernuds's Avatar
well i was concerned because it looked twice as high as the factory istallation, it looked like it was jacked UP!! but anyways ive gotten the s techs installed and i'm quite happy. Though I'll need to get an alignment and probably a camber kit this saturaday (shopwanted me to drive around for a week first)
thanks
h8yourv8
13
Nov 13, 2006 01:48 PM
Melart
Jul 6, 2006 12:05 AM
xuimod
Jan 19, 2006 02:00 PM
syrusstephens
Jun 25, 2005 08:45 PM
kjreinha
Mar 24, 2005 03:55 PM
