tokico hp shocks and springs VS tein s techs
Old Dec 18, 2010 | 11:32 AM
civicexracer's Avatar
Acutally looking into it more, the H&R Sport's you're looking at have about the same drop as the Tein S.Techs, only difference is slightly higher spring rates. For what it's worth, I'd play it safe and go with the Tein S.Techs and the Koni STR.T. There's not a whole lot of information out on the Koni STR.T's and their valving. From my research on them it seems as if their valving is close to the Koni Yellow Sports on their lowest setting, which isn't extremely agressive. The Koni's with the Tein's will last a real long time.
Old Dec 18, 2010 | 11:36 AM
MaximusFunk's Avatar
make sure the koni's are the orange str.t's and not koni reds. I just say that because the reds are not as good quality. Im surprised the oranges are cheaper than HP's.
As for whether they will handle H&R springs, im not sure, but I can tell you that the Koni oranges are designed for lowering springs OR will work as an OE replacement, where as the HP's are just designed as an OE replacement ,BUT people use them for lowering springs. I have heard that the Koni Oranges are just non adjustable Koni yellows on the softest setting. Not 100% sure on that though, cause it wasnt off of Koni's website. If I were you, I would go with the Stechs if its just for daily driving because you will get a much nicer ride.
Also, for thmotorsports.com there is a 3% off code through end of Feb called "threeoffthm2" This is the only current code I could find, but usually they have a dozen or so for specific brands that you might wanna search for.
****I just tested the taxbreak2010 code on a $765 random item and it brought it down to $705. You prolly wont find a better discount code than that.
jakeolas
23
Jun 4, 2008 10:13 AM
fivespeed
Nov 27, 2007 07:06 AM
bigmikew1
Feb 24, 2007 01:31 PM
WhiteRabbit1021
Jan 8, 2007 08:11 AM
jonyg98civicex
Feb 12, 2006 04:20 AM
