stranded car help
On the threaded side that goes inside the cylinder? If so, you may have a bad cylinder. Check the mechanical timing and then compression test the cylinders.
i still can not get it to show the code. when i have the key in the on (II) postion my dash lights do not come on and neither does my clock but when i put the key in between on (I) and on (II) i can get them to come on and the ecu will blink once does that sound like ignition
Innovators
Oct 31, 2025 01:23 AM
illlili
Jan 29, 2011 07:26 AM
