DIY Section Overhaul Project
[edit] Things are changing often. Be sure to glance over the list a little more closely every time you swing by.
I thought it might be a good idea for us to start focusing on what we've all been talking about in other threads: overhauling the DIY section. This has been talked about over and over but no one is working together on it for real so I thought I'd start a thread here in the lounge so we can discuss what we need and start some action. We'll need members and at least one mod/admin on board to volunteer to read through the DIY sections, see what we have, and make the actual changes. Some are outdated. Some have bad links. Some have no pictures anymore due to the forum software upgrade. Some threads don't even belong. Bottom line is this: .:We need to know what DIYs are still usable in their current form. .:We need to know what DIYs can be updated and we need to know who can/will update them. .:We need to know what DIYs are now useless and need to be deleted completely. .:We need links to junk threads that aren't DIYs and need to be removed from the subforums. .:We need new tags for threads that don't have tags so the DIYs can be searched for. Post what you find in this thread and I will edit the first post to reflect what's been done and what hasn't. If a mod or admin volunteers to help, they of course can edit this thread themselves. If you come across a DIY that isn't in the DIY section, post it here so we can move it/fix it. DIY Key: :)=Good, usable, pictures work :(=Needs work :mad:=Completely useless (none of those left!) The HCF DIY List: Exterior (23 DIYs) :)DIY: Remove your EK Rear Bumper (by Wellfedhobo) :)DIY: EK (99-00) LED turn signals (Done by wellfedhobo) :)How to: 96-98 to 99-00 Exterior Conversion (rehosted by wellfedhobo) :)DIY: Installing EJ EK Sidemarkers :)DIY: RSX Windshield Washer Nozzle For Civic :)DIY: Fixing Broken EG Civic and del Sol Exterior Door Handles :)How To: Fiberglassing :)Fog Light Installation Instructions :)How to install headlight assemblies on an 06-08 Civic :)DIY Aftermarket Grill on an EK (fixed, thanks Tony) :)Poll: How to Change 2006 - 2008 Civic Coupe Tail Lights :)DIY 99-00 OEM-style fog light wiring :)DIY foglights 96-98 civic :)DIY Halo Headlights on an Auxiliary Switch (good writeup, could use pictures) :)LED Headlight Accents DIY fixed by wellfedhobo :(How to install a lip kit (Good writeup, needs pictures)(cvcrcr99 will redo) :(How to remove your Bumper and Headlights on an EK (96-00) civic (good writeup, needs pictures)(burnindesirez02 will do) :)DIY quad brake lights By: Fiirkan :)Hybrid Turn Signal Mirrors for 8th Gen Sedans by CameronJr9 (fixed by jprommel, peg_leg, and wellfedhobo) :)Door Handle Replacement/Keyless Entry for 8th Gen Sedans by CameronJr9 fixed by wellfedhobo :)https://www.hondacivicforum.com/forum/showthread.php?t=53797 (former sticky, moved into DIY section by trustdestruction) :(Halo Headlight Installation by skytanker2003 (Needs pics) :(Flip Flop Truck by Crazy_Coupe (Needs pics) Interior (23 DIYs) :)DIY: DC2 Map Light into EG w/Moon Roof (Thanks Danomatic93) :)DIY 96-00 Civic Gauge Cluster :)DIY: EG Dash Trim Piece Removal and Replacement :)DIY Cupholder and Coin Tray in Single Din Slots :)DIY: 94-01 Integra Cluster into 92-95 Civic fixed by wellfedhobo :)DIY custom headliner 96-00 Coupe DX :)DIY custom Door Panel 96-00 Coupe DX :)DIY custom Sun Visor 96-00 Coupe DX :)How to: Gut sunroof EG6 and install nonsunroof cage :)DIY: EG Cluster and Dash Lighting Modifications :)DIY retyped LED cluster Done - reaper2022 :)Vtec light Installation by ludakrishna420 :)DIY: How to pull gauge cluster in a 92-95 Civic done :)DIY 96-98 cup holder fix :)LED Cluster Turn Signals DIY :)DIY Steering Wheel Removal :(Lower Center Console Cover Panel DIY by Windcalmer (formatting issues and pictures are gone) :)Window Regulator Removal, Inspection, Maintenance, Install (fixed) :(Aluminum Pedal Set DIY by windcalmer (Pictures are gone) :(7th gen Gauge Cluster Removal DIY by OpTiCaL (Good writeup, no pics supplied) :(Installing Dual Gauge Pod by XCM828 (Good writeup, pics are gone) :)Weight Reduction 101 by se7ensectoolate :)96-00 center console, radio/temp console removal Drivetrain (26 DIYs) :)Automatic to Manual OBD1 ECU Conversion (added by 94civichatchback) :)Speedometer Cable Replacement (88-91 Civic) (added by punisherinokc) :)Turbo Kit Installation (added by reaper2022) :)DIY: How to Install ES Shifter Bushings by cvcrcr99 (thanks cvcrcr99) :)FAQ: 96-00 LX/DX/CX/HX to EX Exhaust Conversion (moved by Wellfedhobo, thanks addiction2bass) :)How To: Wrap your Exhaust Manifold by cvcrcr99 (done by cvcrcr99) :)DIY: Throttle Body Coolant Bypass :)How to: Make solid torque mounts by cvcrcr99 :)Cam Seal Replacement DIY :)DIY: Fix Your 2-Piece Header's Repeatedly Blowing Midway Gasket :)DIY: Wiring VTEC In Your (Originally) non-VTEC Car fixed by reaper2022 :)DIY: How to Install a CAI (Cold Air Intake) in a 96-00 Civic done by jprommel :)Building a Turbo Kit - What you need, might want, etc... (fixed) :)DIY - Motor Swap from D16A6 to D16Y7 fixed by wellfedhobo :mad:Header Install by asdfbrendan (half of the thread is gone. cvcrcr99 will redo. trying to contact OP) :)DIY Grounding Wire By TheMoogly fixed by wellfedhobo :)DIY Axle Replacement by civicexracer fixed by wellfedhobo :(Civic SRI Install by cderalow (Pics are gone) (burnindesirez02 will do) :)DIY AEM Filter Cleaning by civicexracer fixed by wellfedhobo :(DIY Cam swap for 92-95 Civics (Major formatting issues, pics gone) :(7th Generation Civic Intake Manifold Swap by Chimera (needs extra symbols removed, cant tell if there were ever pics) :)DIY Short shifter install by Street Sniper :)4G DPFI to MPFI Conversion by Kappa22 :(Installing a turbocharger by spoon95 (no pics, extra symbols, seems like there's more to it than that) :)Turbo Kit Installation (former sticky, moved into DIY section by trustdestruction)(remove extra symbols) :)Automatic to Manual Transmission Conversion (former sticky, moved into DIY section by trustdestruction) Detailing/Paint (14 DIYs) :)Wheel Polishing (added by wellfedhobo) :)DIY custom paint your own valve cover (rehosted by wellfedhobo) :)Using Spray Paint Effectively :(Painting Your Valve Cover (2) (Good DIY, needs new pics)(Might be outdated now) :)Washing your car 101 by Xoopiter fixed by wellfedhobo :)Detailing Your Ride by Forty04 :)Cleaning Your Engine by civicexracer :(Painting Parts 101 by Mossy (needs pics) :)Black Paint Care 101 by mikegonzo :)Defogging Headlights (former sticky, moved into DIY section by trustdestruction) :)Headlight Color Change by ineedhp (could use pics but thats unlikely) :)Paint Your Brake Calipers and Drums by mxs :)How To/DIY Polish Si Rims (rehosted by Wellfedhobo) :)Wheel Makeover by mxs (pics located and rehosted by wellfedhobo) Routine Maintenance (24 DIYs) :)Spark Plug Replacement DIY by cvcrcr99 (added by wellfedhobo) :)Manual Transmission Fluid Change (added by trustdestruction) :)Thermostat Replacement (added by cvcrcr99) :)E-Brake Adjustment (added by cvcrcr99) :)How to:Replace your Headlights by cvcrcr99 moved by jprommel :)DIY: Upper Left Motor Mount Replacement - Added - reaper2022 :)DIY Head Bolt Torque Sequences and Specs :)DIY testing for spark and problem troubleshooting by RonJ :)DIY: How to Clean Your IACV :)DIY: Coolant Flush :)Compression Test by Forty04 :(Changing out Spark Plugs by mill$civic (good writeup, needs pictures)(cvcrcr99 will redo) :)Oil Change DIY by civicexracer (fixed by civicexracer) :)Using Sea Foam Motor Treatment by x2100 :)How to Adjust Your E-Brake by cvcrcr99 (thanks cvcrcr99) :)DIY: How to replace your thermostat by cvcrcr99 (thanks cvcrcr99) :(DIY: Bleeding Brakes (needs pictures) (former sticky, moved into DIY section by trustdestruction) :)DIY: Replace PCV valve :)DIY: Replace your Distributor Cap :)Bleeding your Civic Coolant system fixed by wellfedhobo :)Rear Drum Brake Installation by project5k fixed by wellfedhobo :(How to change your transmission fluid (pics gone, extra symbols all over the place)(cvcrcr99 will redo) :(B16 PCV Valve (Pic gone, should be easy to replace)(burnindesirez02 will do) :)Setting Ignition Timing Car Audio/Video and electrical DIYs (15 DIYs) :)Dome Light Fix with Aftermarket Stereo (96-00 Civic) (added by quartus) :)Factory Antenna Replacement (added by mray) :)DIY: Honda Horn Upgrade (thanks Trustdestruction) :)DIY: Glove Box LEDs :)DIY EG "Headlights On" Warning Chime :)DIY: Honda/Acura Stereo Equipment Removal/Installation Instructions for Many Models (All links still good) :)DIY Kill switch/circuit :)DIY Remote Start by 90Civtegra :)Factory Antenna Replacement :(Wiring Help by windcalmer (Good info but pics are gone) :(In-floor Subwoofer Install ofr 96-00 Civics (No pics, video link dead) :(Rear Speaker Installation, 96-00 Coupe by Solid_Snake (Okay writeup, but is only halfway done and links the rest to this one) :(Rear Speaker Installation by remington870_20ga (Pics are gone) :(Rear Camera Installation by Mobile AV (Good writeup but pics are gone) :)Dome Light with Aftermarket Stereo Fix by HXville Suspension and steering DIYs (8 DIYs) :)Converting Power Steering Rack to Manual (added by trustdestruction) :)DIY Upper Strut Bars (Coupe/Sedan) (done by Scott53092) :)Front sway bar a diy by brokenarmboy19 fixed by wellfedhobo :)Coilover sleeve DIY :)91 Civic Shocks / Strut Replacement by Droopy128 (pictures fixed, thanks Droopy128) :(Upper Control Arm Replacement by Fiirkan (Pics gone) :)5th Generation Trunk Bars by civicexracer (fixed by civicexracer) :)DIY Shocks/Springs (rear) install by Street Sniper :)Replacing Wheel Studs by Street Sniper Here is a list of DIYs that we probably need to add once we get the overhaul in full swing: DIY Rear LCA's (cvcrcr99 will write) DIY Clutch Replacement (cvcrcr99 will write) :)DIY: Interior Detail Extra Attention (I have an issue with using bleach on interior surfaces. Is it only me, though?) Valve cover gasket (burnindesirez02 will do) (maybe) head gasket (burnindesirez02 might do) Oil Pan gasket (burnindesirez02 will do) Complete Tune up (burnindesirez02 will do) Front brakes: Rotors and pads (burnindesirez02 will do) Rear brakes: Rotors and pads (burnindesirez02 will do) Chop Shop tutorials (in the chop shop section) :)DIY: How to shave your car via photoshop (Superize, fix the last pic plz) Here's a list of threads that could be useful if they were redone: :(GReddy_Civic's Detailing Thread (Good info on products, could be rewritten to be more useful. Nice pics though.) Here's a list of threads that need to be deleted/evaluated: 10 deleted Here's a list of DIYs that we should bring in from other forums and repost here: How to: 6th Generation Black Housing Headlights (at club Civic, has pics that should be rehosted on HCF) |
I'll be reading around in the exterior DIY section for a bit
Non-DIYs deleted.
Also, to anyone who sees this: any ideas for other DIY sections? I feel like there's some DIYs that don't really belong in any of the sections we have. Maybe something like: Exterior Interior Drivetrain Suspension Engine Detailing/Paint or something like that. |
(Post 693113)
Exterior
Interior Drivetrain Suspension Engine Detailing/Paint Exterior and Interior are pretty much good. Engine should cover a lot. Detailing/paint could cover both interior and exterior because we have DIYs on painting both interior and exterior parts. Should we call it something like Detailing/Paint Care? or do we want painting DIYs to stay with paint regardless of whether it's interior or exterior? |
Also, why are the DIY section and Product Review section formatted differently? That makes no sense to me. Look at the main page and you'll see what I mean.
(Post 693120)
Why doesn't it look like the other sections where you can see the title of the most recent thread? I bet more people would visit that section of they got a preview of the most recent thread title. More people viewing it on here, the more people can possibly link it on other sites when other have a question the the DIY would answer. For example... "How to: <what's being done>. By: <name of user>", or "DIY: <what's being done>. By: <name of user>" Edit: WellFedHobo, you can update that first post in this thread to say "(cvcrcr)" next to the "96-00 Civic HX, DX, LX, EX, Si Headlight Bulb Install", and "How to install a lip kit". I'll go ahead and re-do them entirely. Reaper can go ahead and delete once I remake them, I'll PM him when that's done. I should be able to do it soon. Edit #2: J/w, Wellfedhobo, have you only gone through the exterior DIYs, correct? Once you go through let us know about the others that need to be fixed/updated, I'll definitely sign up for more to re-do/update. |
ill add on how to install a steering wheel pretty soon lol, my friend wants a steering wheel installed........ you will all giggle at it, funny thing is im the one who gave it to him for christmas,
Hobo, make sure you get RonJ's DIY on how to check for spark, too.
https://www.hondacivicforum.com/foru...ad.php?t=74362 It should be a sticky in the Gen. Tech. section in addition to being in the DIY section. Maybe we should create a section under DIY for "Troubleshooting"? |
Originally Posted by cvcrcr99
(Post 693127)
I think we should definitely have a specific tag(s) that people could use to easily search for all DIYs. Something along the lines of "DIY, How to, Install guide". Also, I think we need to have a format for the DIY guides.
(Post 693135)
Unfortunately, DIY is 3 letters and we can't search for anything less than 4...
forget what I said before, i thought they were yours for some reason. Yeah, rewrite some and post the links here so they can be added. Right, I've only gotten that far. If anyone else takes a section, let me know. |
| All times are GMT -8. The time now is 01:12 AM. |
